uht-o...is this gonna be a problem?
Just put my I.M. butterfly valves back in and i did not get the perfectly centered, did not notice until I was on the 4th one. By that time the thread locker was doing its job (on the threads and the butterfly valve "shaft" and it actually broke the head on my #1 Philips when trying to remove the screws. The light shining thru is form a flashlight behind the valve and the valve is as closed as it will go.
<a href="http://s4.photobucket.com/albums/y145/pharoah007/?action=view¤t=DSC04125.jpg" target="_blank"><img src="http://i4.photobucket.com/albums/y145/pharoah007/DSC04125.jpg" border="0" alt="Photobucket"></a>
<a href="http://s4.photobucket.com/albums/y145/pharoah007/?action=view¤t=DSC04126.jpg" target="_blank"><img src="http://i4.photobucket.com/albums/y145/pharoah007/DSC04126.jpg" border="0" alt="Photobucket"></a>
So is the leak of air into the secondary runners during low RPM's going to affect my engines running. i do not know how sensitive the intake is to this kinda thing.
Man I suck
permatex permanent sure works good/fast
<a href="http://s4.photobucket.com/albums/y145/pharoah007/?action=view¤t=DSC04130.jpg" target="_blank"><img src="http://i4.photobucket.com/albums/y145/pharoah007/DSC04130.jpg" border="0" alt="Photobucket"></a>
Man I suck
as long as there's no "binding" you'll be fine... BUT...
you didn't open up or make those bores wider did you? May just be the light shining thru but because those bores are "plate-mated" for diameter they shouldn't be made larger.
Yes, but the amount of heat it takes to accomplish that will also melt the plastic bushings...
on both sides of the butterfly plates that act as bearings and permit the butterfly shafts to rotate freely.
no I did not open up the bores....
can you please explain what you mean by "plate-Mated"?
There is no binding; I will push the assembly to extremes to be sure when I go home (at work)
So if it does not bind, then this small leak at low RPMs will not affect the performance of my engine...good to know.
"plate-mated" means that bore has a specific gap around the plates...
if it's enlarged or the plate diameter reduced then too much air gets past the plates during low RPM which would lead to reduced low-end torque and poor low-end performance. You can do ANYTHING before/after those plates but absolutely NOTHING to the runner wall ID where the plate sits when fully closed.
Imagine a throttle body butterfly plate that didn't meet the venturi walls when closed. Car wouldn't idle or run very well until high RPMs.
Re: "plate-mated" means that bore has a specific gap around the plates...
humm, so there will be substantial air getting thru my butterfly's to ruin low end performance with my butterflies like this (off center but not binding)?
(I did NO porting to the "plate matted" size where the butterflys sit, the valves themsels are just on there a bit askew and as such there are cracks where you can see the light getting thru)
I know you are not a physic but you have MANY years exp with this kinda stuff so your opinion is a solid one.
thanks.
Z.
thanks.
Z.
There's a several reasons your plate-to-wall gaps could seem overly large...
firstly you've got a light source behind them which could cause gaps to appear larger than they are. Secondly your butterflies may not be in the fully "closed-and-locked" position. Thirdly it may just be an illusion caused by the extreme pic magnification and aggrivated by the lighting.
But in a worst-case scenarion the 12V IM's have a provision for adjustment of butterfly "closed" position on the back near the butterfly linkage that acts as a "stop" when they're fully closed. If the top/botoom were not set up as an "assembled unit" that adjustment may be outta whack... or it could be just a poor adjustment from the factory. There's a small pin back there with a larger round "wafer-like" head. To get more closure you need to tap that pin "in" (towards engine block) a little. To get less closure you need to tap that pin "up" a little from the underside of the IM. The pin is easy to spot as it's what acts as the "stop" for the butterfly linkage thats tops out on that pin when butterflies are fully closed.
understood. Will play with the pin when I get home. So it is not threaded and I just tap it with....
a punch.
thanks so much, I know EXACTLEY the pin you mean but NEVER would of thought of it!
Z.
Z.
Bingo and that's why there's no slot, hex or Phillips provision. Try to turn it and ya risk...
snapping the head off. And when tapping it from the top try very hard to center the puch in the wafer head or you risk breaking the head off if ya tap it near it's outer edge.
But there's several options for replacing a broken one so the IM is not a paper-weight if it happens.
