what is the ohm value for the spark plug wires on a 12V.....
the OEM Bremi ones.
I have a used set of wires and I want to test them and see what set is in better shape.
If not then you have to put it on 200K ohm because 5K ohm is out of range for the 0-2k ohm setting. If it's digital it should read about 5 in its K-ohm scale. If its analog then you have to read from the K-ohm scale and look at the increments. Half way up is 100K and probably marked so, 1/4 way up is 50K and so on. I probably can't help much more than the manual.
The cable alone makes 1 kOhm.
At the end of the cable the connector to place the spark plug alone makes 5 kOhm.
If you measure interior of the connector to the other end of the cable , that made 1 kOhm + 5 kOhm = 6 kOhm.
80Quattro
11-27-2013 08:27 AM
audiPete
09-24-2008 07:19 PM
sidespar
11-25-2004 07:33 AM
sidespar
11-22-2004 02:28 PM
