what size is the collar bolt for the axle shaft...
that connects to the hub? Trying to change out my CV Axle joints. I'm reading the write-up by AndyTN, and it says 23mm on his '97. Is there that much of a difference in bolt size on a '96? I'm using a 27mm drive and it still feels a little loose. Also, is it suppose to be that difficult to remove the bolt? TIA
Front is 27mm, rear was 24mm on my '96. Just did cv joints on the front last week, and rear wheel bearing...
make sure you keep the socket square on the nut so it doesn't slip off, those puppies are way torqued down. I bent my first breaker bar trying to break'em loose. Ended up using the handle on my jack
sj6sp
04-15-2007 09:48 AM
polo92gsr
16
10-13-2005 10:35 AM
