What size hose?
There is about a 2-3" long section of hose at the front right of the IM on my 96 A4 12V (below where the right 3 spark plug wires are hooked to the coils). One end slips over a brass fitting that connects to the IM and the other connects to a pastic tube that then runs towards the back of the engine. This hose is only visible when the plastic engine cover is taken off.
The hose as a crimp clamp on the brass end and a regular hose clamp on the plastic tube end.
What is this hose for? It is cracked on the outside, so I suspect it could start allowing a vacuum leak. Dealer wants ~$30 for this hose. Is it a regular hose or does it have different ID on each end? The plastic tube OD was roughly 12mm.
What should I get?
Thanks,
Byas
What should I get?
Thanks,
Byas
I pulled out the hose and measured the brass fitting -- it is about 11.5mm. Is there such a size of hose or will a 12mm hose work? This hose/tube combination connects to the brake booster.
Byas
Byas
RedDragoN750
Audi 100 / A6 (C4 Platform)
01-28-2008 05:27 AM
S4Rye
03-14-2005 01:53 PM
UrSoccer_mobileĀ®
Audi Original "S" Cars
09-02-2004 11:33 AM
