2005 AUDI A4 2.0 012555
Welcome this is Robert.This car came to me and still the same code comes up ( 012555 - Low Pressure Fuel regulation ) If this helps you I will give you a list of what was replaced in this car: electric fuel pump, fuel filter, HPFP fuel pupm, low fuel pressure sensor G410 ,cam followers and put the breathing valve (Basic Setting 103 Field 4 shows "ADP. O.K.").
.If you could help me witht he problem for this car I would be most grateful, because in this car almost everything is replaced, yet still I get the same exact code. Thank you so much in advance. Robert
012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
P310B - 008 - Implausible Signal - Intermittent
008583 - Bank 1; System too Lean at Idle
P2187 - 004 - No Signal/Communication
001287 - Idle Control System RPM: Higher than Expected.
P0507 - 001 - Upper Limit Exceeded - Intermittent
Hello,
Yes this car is really very good in all things i also have one. few weeks ago its suspension get some problems and mechanic told me to change them so i just change them. i bought sway busing bar from here on ebay at very good rates that i don't found any where else.
smashtheqube
RS4 (B7 Platform) Discussion
07-17-2007 04:31 PM
