2017 A3 can't pump gas in and miss fires while driving
Hey AudiWorld need some advice. Car flat died at a red light the other day on my daughter. I get there after some good Samaritans have pushed her out of the road. The car started up fine for me grant it had been 30 minutes. It has been one heck of a hot summer with temps over 100 daily. I started driving the car home. On the way home it missed several times on and off. Each time the engine light flashed. It only had about 50 miles worth of fuel so i decided to stop and get gas. It would not take any gas no matter what i did. I was getting more on the ground than in the car. Like the pump had .3 gallons on it. I went on home with it had in it. Later that evening i went to look at car again. Pulled the gas cap off then all the sudden it started spitting gas out the neck. I put the cap on quickly back on. Waited a minute and tried again. then all the sudden you could here the tank vent. Decided to drive to gas station and try again, to no avail. It still wouldn't take fuel Don't know how long it has been gone but the flap in the fuel neck is gone. Could have been missing forever idk. I pulled the pump to look in tank and tried to look with a scope down the neck. Never found the flapper. With the pump out I could put gas in it with a gas can. Did find out my daughter would always go to the nearest dollar after the pump clicked. Put the pump back in and started it up drove around. When i got home from going around the block I turned the car off. GAs started coming from under the car. I pulled the rear tire and fender well to expose the carbon filter. Took it apart to find gas in it. All this time driving in neighborhood it would miss fire. No code for EVAP only the miss fires. I have a new carbon canister and valve coming but not sure if it got messed up because of a different issue. Thanks for reading and any help.
![](https://i.ebayimg.com/images/g/8QkAAOSwmfFk-PNY/s-l1600.jpg)
Yes if the EVAP canister is not working properly, basically it's saturated with fuel and not absorbing the vapor, then you can get misfires. The purge valve could also be damaged and not releasing the vapor it still traps into the engine. You have a problem in the closed circuit emissions control system, so that can lead to misfires and other issues. First thing is to replace the canister and then take it from there.
S4inSoFla
09-26-2001 05:20 AM
BrianS
03-12-2000 10:05 AM
