APR Presents - Carbonio 2.0 TSI Carbon Fiber Race Engineered Ram Air Intake
<b>2.0TSI Carbonio Intake</b>
<a href="http://www.goapr.com/Audi/products/intake_carbonio_20tsi.html">http://www.goapr.com/Audi/prod....html</a>
<img src="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_013.jpg">
Carbonio's latest carbon fiber intake for the 2.0 TSI engine is a truly race engineered ram air design that is available for the first time as an affordable street car intake system. Building from years of experience on and off the race track, Carbonio's and APR's engineering teams have spent countless hours developing a true cold air and ram air carbon fiber design that can be recreated affordably for the street performance enthusiast.
For many years professional motorsport organizations have suffered great expense to properly tune the air intake delivery system for transverse turbocharged engines for use in endurance and sprint races where every last horsepower and pound feet of torque can make the difference in position when crossing the finish line. Historically these designs have proven to be the most efficient and powerful although the most expensive to produce.
<b>VW Motorsport - Germany - Scirocco GT24</b>
<a href="http://www.vwvortex.com/artman/publish/volkswagen_news/article_2306.shtml"><img src="http://www.goapr.com/VW/products/images/vwms_scirocco.jpg"></a>
<i>Click to learn more about this vehicle</i>
Aftermarket performance companies have attempted to capitalize on these designs however the cost restraints have typically resulted in compromise and deviation from the true engineering principles associated with motorsport accomplishment. Don't be fooled by catch phrases and tag lines alluding to a new intake technology or special design characteristic. You won't see any of these gimmicks installed on race cars at the Nurburgring.
Carbonio and APR have gone even further to maintain all oem specifications necessary to integrate cohesively with an otherwise stock engine to avoid raising eyebrows at the dealership. Flexibility was another characteristic of Carbonio's and APR's design whereas the new TSI intake is also suitable for Stage 1 and Stage 2 modified engines all the way up to and beyond APR's Stage 3 Turbocharger System.
APR first unveiled Carbonio's TSI Intake System at SEMA 2008 in Volkswagen Group of America's Concept CC and Tiguan.
<b>VW GOA SEMA 2008 CC</b>
<a href="http://www.vwvortex.com/artman/publish/vortex_news/article_2529.shtml"><img src="http://www.goapr.com/VW/products/images/sema_cc.jpg"> <img src="http://www.goapr.com/VW/products/images/sema_cc_engine.jpg"></a>
<b>VW GOA SEMA 2008 Tiguan</b>
<img src="http://www.goapr.com/VW/products/images/sema_tiguan.jpg"> <img src="http://www.goapr.com/VW/products/images/sema_tiguan_engine.jpg">
Ram air induction is accomplished by maintaining the oem air inlet opening at the front of the leading hood edge which is the highest pressure area of airflow across the entire vehicle. Placement of the air filter as close to this high pressure zone as possible results in overcoming some of the airflow restriction created by even the highest flow air filters available.
<b>MAF Readings</b>
<img src="http://www.goapr.com/images/20tsi-maf.gif">
Cold air induction is accomplished by completely sealing the intake system from the hot engine bay air and then taking it even further through the choice of Carbon Fiber material and an additional thermal barrier application to the inside of the intake system. Quite often intakes are advertised as cold air induction even though the material choice is a metal or plastic composite which simply does not insulate the incoming air from the hot engine bay air or does not completely seal the intake system in the engine bay allowing hot air to enter the intake stream negating any cold air induction gains.
<b>Dyno Performance</b>
<img src="http://www.goapr.com/images/20tsi_carbonio_dyno.gif">
<b>Benefits of the Carbonio CAI System include:</b>
<b>»</b> Increased Horsepower and Torque
<b>»</b> Improved Throttle Response
<b>»</b> Decreased Turbo 'Lag'
<b>»</b> Flattened Torque Curve (engine is less 'peaky')
<b>»</b> Improved Fuel Economy
<b>»</b> Enhanced Engine Volumetric Efficiency
<b>»</b> Enhanced Sound of Turbo Diverter Valve
<b>»</b> Installs in an Hour (does not require bumper or headlight removal)
<b>»</b> Maintains Clean Appearance by Retaining Factory Engine Cover
<b>»</b> Maintains All Factory Emissions Components
<b>»</b> Fits Both Manual and Automatic Transmissions
<b>»</b> Unique Thermal Barrier Composite Construction Ensures Low Inlet Temperatures
<b>»</b> Fully Compatible and Complimentary with APR Software and Exhaust systems
<b>Each Carbonio Kit Includes:</b>
<b>»</b> Aerospace Grade Carbon Fiber Main Section
<b>»</b> Carbon Fiber Main Section Show Quality Finish
<b>»</b> Complete Photographic Instructions
<b>»</b> All Necessary Hardware Included for Easy Install without Cutting Or Modifying
<b>Detailed Photos</b>
<i>Click to Enlarge</i>
<a href="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_001.jpg"><img src="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_001_th.jpg"></a> <a href="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_002.jpg"><img src="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_002_th.jpg"></a> <a href="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_003.jpg"><img src="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_003_th.jpg"></a> <a href="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_004.jpg"><img src="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_004_th.jpg"></a> <a href="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_005.jpg"><img src="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_005_th.jpg"></a> <a href="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_006.jpg"><img src="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_006_th.jpg"></a> <a href="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_007.jpg"><img src="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_007_th.jpg"></a> <a href="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_008.jpg"><img src="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_008_th.jpg"></a> <a href="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_009.jpg"><img src="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_009_th.jpg"></a> <a href="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_010.jpg"><img src="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_010_th.jpg"></a>
<b>Installed Photos</b>
<a href="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_011.jpg"><img src="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_011_th.jpg"></a> <a href="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_012.jpg"><img src="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_012_th.jpg"></a> <a href="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_013.jpg"><img src="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_013_th.jpg"></a> <a href="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_014.jpg"><img src="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_014_th.jpg"></a>
<b>CBFA Breather</b>
<a href="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_015.jpg"><img src="http://www.goapr.com/VW/products/images/carbonio_intake_mkv_tsi_015_th.jpg"></a>
<b>Pricing</b>
CBFA engines REQUIRE the extra Breather Filter
Passat/CC/Tiguan REQUIRE the extra Ram Air Bracketry
<b>Intake - $299</b> - GTI/Jetta/EOS/A3/Passat/CC/Tiguan - 2.0 TSI (CCTA/CBFA) - <a href="http://store.goapr.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=AS&Product_Code =CI100020">Buy One Now</a>
<b>Breather Filter - $15</b> - GTI/Jetta/EOS/A3/Passat/CC/Tiguan - 2.0 TSI (CBFA) - <a href="http://store.goapr.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=AS&Product_Code =CI100020A">Buy One Now</a>
<b>Ram Air Bracketry - $20</b> - Passat/CC/Tiguan - 2.0 TSI (CCTA/CBFA) - <a href="http://store.goapr.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=AS&Product_Code =CI100020B">Buy One Now</a>
<b>MAF Readings</b>
<b>Pricing</b>
APTuning, LLC
Q5/SQ5 MKI (8R) Discussion
09-02-2011 10:00 AM
APTuning, LLC
S4 (B8 Platform) Discussion
05-27-2011 02:11 PM
Tony@EPL
01-29-2009 04:17 AM
Arin@APR
Audi A3 / S3 / RS 3
01-09-2009 02:36 PM
