CAEB Gaskets?
Does anyone have a list of all of the gaskets and recommended parts that should be replaced when doing an engine swap?
2009 A4 2.0TFSi Quattro, engine code CAEB.
Your help is extremely appreciated. Thank you!
You should look at engine rebuild and engine swap threads in the B8 A4 forums here and at audizine. Parts lists have been posted before.
Basically, you should be working from the workshop manuals (erwin.audiusa.com, pay for a day, get all the PDFs for your VIN), and anywhere you dismount something, if the manual diagram marks a bolt or gasket as replace if removed, there you go.
Obvious ones would be the throttle valve gasket if you remove it from the IM, IM gasket if you remove it from the cylinder head, turbo gasket if you remove it from the cylinder head, and cat to turbo gasket as you'll definitely be making that separation.
galaxys (01-17-2023)
S4gasm (LoTR)
12
07-01-2007 11:06 AM
canuck699
03-03-2006 06:04 PM
Cerveza
09-06-2002 08:19 AM
tberry
08-06-2002 07:20 AM
