VIS balance shaft delete +pick up pipe TFSI (quick vid )
in this episode I will be showing you how to remove and fit a VIS free wheel balance shaft delete on my mk2 Audi TT EA113 engine along with fitting a new oil pick up pipe VIS Motorsport Balance Shaft Freewheel Deactivation Sprocket - 2.0T FSI EA113 VIS Motorsport's oil pump sprocket replaces the weaker OEM VAG two-piece sprocket (06F105243C) found on the TFSI Engine. This sprocket can be used for oil pumps with a balance shaft delete, or alternatively can be used to deactivate the balance shaft by removing the main cog inside the oil pump.
carchris
TT (Mk2) Discussion
12-10-2023 09:00 AM
Pchelka01
09-07-2012 07:39 PM
Rolf
04-28-2007 01:22 PM
