'05 allroad 2.7t
if chipped, it then depends on what chip you have
most stage 1 or 2 chips are still just fine, and actually tested, with the stock plug
while you are running more boost with them, the stock plug is actually well designed with a low resistance to allow it to spark quite well
if you really want to change your plugs often, and at 95k, you've gone about 55k too long, go with NGK BKR6E - they are a copper version of the stock plug. You can also go with the NGK BKR7E plugs, which are one range colder, but really no need. Understand, you'll probably have to change them every time you change your oil, though.
you have options for your plugs. aside from those already mentioned, there is a Bosch sidefire plug available. i think VAST sells it, but you'll have to double-check that. it seems to be attractive to people because you don't have to mess with the gap. so far, i haven't heard anything negative about them.
from what i gather, you can get longer life from these plugs if they are gapped correctly. it seems not many people do that before installing them.
You guys are killing me.
I placed an order from Blau the day before the first plug recommendation and threw plugs on it. Ugh.
I ordered the only one they listed, which is NGK6458 .
I asked about getting them changed a while back and the indi told me I didn't need to until 100k.
I assume the plugs I ordered will do. I know nothing about plugs.
bigstothel
08-10-2004 11:23 AM
A4edge
11-21-2003 09:23 AM
