2.7 Biturbo no start after engine install
Hi Just finished mounting the engine after a Bi turbo replacement, got the pair for $850 a piece, from turbochargerpros.com, that is new not overhauled. Enyway I can't get the cart started it cranks but no start, there were no fuel at the engine after cranking so I did the fuelpump test prosedure where you remove the fues and hot wire the pump, the pump worked and I now have fuel at the engine but still no start.
Thank you, I was also thinking of getting the Wag-Com diagnostic software from Ross-Tech LLC, is this a good choice or is there something better or more user friendly on the market. Thanks again Kris
rotational sensors aren't functioning then the fuel pump/spark circuit won't fire. Read the 2.7t study guide and figure out what inputs are needed for the CPU to know the engine is turning.
Just got it running, I rechecked the connection on the MAF, ECU and the engine speed sensor, the speed sensor connection plug came apart when I pulled lightly on it, so that might have been the killer. But thanks for all the help. Kris
shxuila
12
04-23-2017 09:18 AM
mathieums
09-06-2011 08:43 PM
DaveThompson
02-03-2005 12:59 PM
