2001 A6 2.7t error codes need help
Each code represents a different failure in the motor management system.
If the code is for a bad O2 sensor, then replacing the sensor is probably the fix for this. If it is for a vacuum leak, then fixing the vacuum leak will probably fix the code.
I am wondering what can cause my obd2 not to work, i used a diagnostic tool and it doesnt connect... What can it be? I have 2001 audi a6 quattro 2.7t awd...i would like to see the codes but cant go through!
gb944
VAG-COM Discussion
04-20-2005 07:01 AM
Frank C
VAG-COM Discussion
01-24-2004 04:47 AM
