Allroad battery/alternator problem
Old 07-03-2012, 02:47 PM
TheAudiGirl's Avatar
Default Allroad battery/alternator problem
I have a 2001 Audi AllRoad 2.7T automatic. I brought the car in to the Audi dealership and was told it needed a new battery. New battery was installed and was then told it needed a new alternator. New alternator was installed and the charging system still had an issue. The battery was checked and is good. Replaced the new alternator with another new alternator and the charging system still has an issue. Mechanic says he checked the connections and everything is fine and is now at a dead end. Any suggestions or ideas?
Thank you,
AudiGirl
Old 07-03-2012, 07:40 PM
ezveedub's Avatar
How are they coming up with the idea it needed two alternators and still doesn't charge? I'm trying to determine how they are determining the charging issue, as it's mainly only the battery, alternator, main ground cable to the body or the positive cable wiring from the alternator to the battery that would cause faulty charging. The D wire from at the back of the alternator triggers the charging at idle from start up, but usually if you rev the engine up, they start charging anyway. What dealer is this car at?
Old 08-23-2013, 05:52 AM
cisco304's Avatar
I have the same problem with my '01 Audi Allroad. I found that the wires from the alternator was touching the body and was corrosive from underneath. I had to cut and splice, but eventually will need to replace the wiring from alternator connector to battery or where it connects in between.
Old 01-28-2015, 03:01 PM
Tonytomasi's Avatar
Thank you,
AudiGirl
what was the problem? getting tired of replacing all this stuff
Old 02-09-2017, 05:54 PM
Allroads_Lead_Somewhere's Avatar
Default Audi Allroad Electrical / Charging problems
I know, right?!?
I wish people would take the time to report what resolved their problem. WTF is this forum for, if not the exchange of Problem - Troubleshooting - SOLUTION REPORTING.
I am so f'ing sick and tired of douchebags whom come a running for our help, yet never retun with the solution they find for their problem.
Maybe there is no longer a controlling Administration for this forum, but if there is, maybe he will start clamping down on these Hit N Run *******s that use the forum, for completely selfish purpose. Kick their asses off the forumn.
It's a huge problem and making visiting AW an almost worthless experience.
Shame!
Old 02-15-2017, 09:52 PM
Tonytomasi's Avatar
Default The
Originally Posted by Allroads_Lead_Somewhere
I know, right?!?
Shame!
forums kinda duck these days for that resson, no updates. Facebook audi c5
​​​​Allroad group
so to fix my issues I replaced the lines running from the alternator to the battery and the ground on the battery. While in there might as well
I just replaced the starter on the 6 speed, upgraded the lines, while your in there. I went with 0/1 gauge, all the way around. Over kill is best for these cars. On the automatic I noticed better voltage, less drops (there's subs in the trunk) and no issues.
fixed Ill call it at this point. Stock wire looks to be thin 4 gauge maybe little smaller? If ou don't want the big wire to play with. I used ofc, big 3 kit 50 bucks and it's done.
there's my story.
FlackoFlo (01-26-2021)
AudierJC
9
01-31-2021 07:20 AM
MauriceAvec
03-05-2020 06:40 PM
mrmelo2
Q7 MK 1 Discussion
13
02-22-2020 04:44 AM
carlr
Q7 MK 1 Discussion
12-28-2014 11:21 PM
nguyen1368
12-16-2005 12:45 PM
Quick Reply: Allroad battery/alternator problem
