Boost problem / leak I have problems with the boost, recently I installed
#11
Posted by: svenson69 on 2005-08-23 15:58:01
Account #: 90758
Boost leak / Still having problems after several tests, I have replaced the Forge Valves
with the original 710N`s, put in a new TBB and F-hose, no change, then made the test with the vacuum tester from AWE. I found no boost leaks, no sound of leaks.
Today I put in the VAG-COM with a friend, still throwing the following code
17965 - Charge Pressure Control: Positive deviation
What should be my next step? Perhaps a leak in the forge exhaust(burned gaskets) or intecooler problem?
Please help
Account #: 90758
Please help
#14
After that, you could have an IC hose leaking or, somehow, bad DVs. Check the little hoses to the DVs as well as test how tight they are to the DVs. Maybe your N75 valve went bad?
svenson69
10
10-31-2007 03:07 PM
Z-Tuned (Alex)
12-16-2006 08:12 AM
denic992-- JAYHAWK
09-14-2004 09:39 AM
