Boost spikes with GIAC X chip a problem? Details inside...
Old 02-15-2008, 09:02 AM
boostbuddy's Avatar
Default Boost spikes with GIAC X chip a problem? Details inside...
I finally ran a couple of WOT logs using VAG-COM.
Graphed requested vs. actual boost.
Requested boost was about 1.8 bar (can't remember exactly), while actual boost was about 2.4 bar.
I know that these values are insanely high for a stock K03 2.7T. They were very short peak numbers.
How do I know if I need a MBC? Are there other tests to perform? I don't go WOT very often, but I don't want problems that could be easily avoided.
Thoughts?
Old 02-15-2008, 09:08 AM
quickaudi:STFA's Avatar
is that the latest Giac code?
Old 02-15-2008, 11:04 AM
boostbuddy's Avatar
Not sure, but chip flashed in September 2007.
Old 02-15-2008, 02:16 PM
Default maybe post the logs if you run again? overshooting boost isn't a good idea
do you have a boost gauge?
Old 02-15-2008, 03:26 PM
boostbuddy's Avatar
No, I don't. Looking in to getting one, but no easy options for A6 that I have found.
Old 03-08-2008, 05:01 PM
New Member
jussloozit's Avatar
Default Re: Boost spikes with GIAC X chip a problem? Details inside...
experienced similar problems. hesitation in the rpm range around 4.5. sometimes more than once up the rpm range. reflashed by autospeed and its like night and day. no hesitation and a smooth boost curve thru every gear. very satisfied
Robert Paulson
02-08-2008 05:18 AM
p3u
07-27-2005 06:12 AM
DenverNoob
02-06-2005 11:56 AM
BLKB6A402
04-05-2004 05:14 AM
Billy531
05-19-2003 02:15 PM
Quick Reply: Boost spikes with GIAC X chip a problem? Details inside...
