Codes
Car is 2002 Allroad 2.7T tiptronic
Had run a scan a few days ago. Cleared codes. Ran again today, see below.
trans code 17125 P0741 : are there troubleshooting procedures to determine what the cause is? Kiss of death for torque converter?
engine codes:
17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground P1454 - 35-00
==> Bad sensor? needs to be changed? Location?
17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat) P1296 - 35-00
==> Which temp sensor or thermostat is meant? Location?
Air Bag code (light is on):
65535 - Internal Control Module Memory Error 00-10 Intermittent
==> suggestions for troubleshooting? (I had been fighting air bag code (seat, driver and passenger side) on my A4 (B5). Finally solved when cutting out the connector under the seat.)
Instrument code:
00562 - Sensor for Oil Level/Temperature (G266)
30-00 - Open or Short to Plus
29-10 - Short to Ground - Intermittent
==> Change G266 sensor? Location? Can it be tested?
VCDS Version: Release 10.6.4
Data version: 20110418
Saturday,13,August,2011,20:07:47:22662
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
VIN: WAUYP64B01N092578
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551 M
Component: 2.7l V6/5VT G 0001
Coding: 06752
Shop #: WSC 05141
VCID: 4D9F9DE9AD41
WAUYP64B01N092578 AUZ7Z0Y1652764
3 Faults Found:
P1454 - 35-00 - -
P1296 - 35-00 - -
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 35-00 - -
Readiness: 0000 1100
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4Z7 927 156 A
Component: AG5 01V 2.7l5VT USA 1414
Coding: 00002
Shop #: WSC 00000
VCID: 4489B8CD7E0B
1 Fault Found:
17125 - Torque Converter Clutch: Stuck OFF / No Power being transferred
P0741 - 35-00 - -
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4Z7 907 389
Component: ABS/ESP allrad D57
Coding: 06397
Shop #: WSC 02325
VCID: 091769F919A9
No fault code found.
Address 06: Seat Mem. Pass Labels: None
Part No: 4B0 959 760 C
Component: Sitzmemory R1 BF 0102
Coding: 00003
Shop #: WSC 00000
VCID: 2D5FFD69CD81
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No: 4B0 820 043 AG
Component: A6-Klimavollautomat D65
Coding: 00160
Shop #: WSC 02314
VCID: 5FC357A1F7AD
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No: 4Z7 959 655 C
Component: Airbag Front+Kopf 1002
Coding: 00307
Shop #: WSC 02325
VCID: 4FA387E1A74D
1 Fault Found:
00-10 - - - Intermittent
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4Z7 920 980 B
Component: C5-KOMBIINSTR. VDO D13
Coding: 02264
Shop #: WSC 05141
VCID: 438BBBD17B05
2 Faults Found:
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 B
Component: - 2C1A1 X031
Coding: 25500
Shop #: WSC 05140
VCID: 4489B8CD7E0B
3 Faults Found:
01400 - Suspension Level Control
11-00 - Control Limit Not Reached
01577 - Turn-Off due to Over-Temp
35-10 - - - Intermittent
01772 - Signal from Level Control Pressure Sensor (G291)
27-10 - Implausible Signal - Intermittent
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D33
Coding: 15885
Shop #: WSC 02314
VCID: 3061E41DDAB3
2 Faults Found:
01560 - Passenger Door
59-10 - Can't Unlock - Intermittent
01562 - Right Rear Door
59-00 - Can't Unlock
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
Shop #: WSC 00000
VCID: 2C59F06DF69B
Address 45: Inter. Monitor Labels: None
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00102
Shop #: WSC 02314
VCID: 264D0245E877
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D05
Coding: 00030
Shop #: WSC 02314
VCID: 040978CD3E8B
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 195 A
Component: Radio D00
Coding: 00204
Shop #: WSC 02314
VCID: 1E3D2AA5B027
End ---------------------------------------------------------------------
engine codes:
Instrument code:
75 76 77
Coding: 06752
Shop #: WSC 05141
VCID: 4D9F9DE9AD41
3 Faults Found:
P1454 - 35-00 - -
P1296 - 35-00 - -
P1624 - 35-00 - -
Coding: 00002
Shop #: WSC 00000
VCID: 4489B8CD7E0B
1 Fault Found:
P0741 - 35-00 - -
Coding: 06397
Shop #: WSC 02325
VCID: 091769F919A9
Coding: 00003
Shop #: WSC 00000
VCID: 2D5FFD69CD81
Coding: 00160
Shop #: WSC 02314
VCID: 5FC357A1F7AD
Coding: 00307
Shop #: WSC 02325
VCID: 4FA387E1A74D
1 Fault Found:
Coding: 02264
Shop #: WSC 05141
VCID: 438BBBD17B05
2 Faults Found:
Coding: 25500
Shop #: WSC 05140
VCID: 4489B8CD7E0B
3 Faults Found:
Coding: 15885
Shop #: WSC 02314
VCID: 3061E41DDAB3
2 Faults Found:
Coding: 00001
Shop #: WSC 00000
VCID: 2C59F06DF69B
Coding: 00102
Shop #: WSC 02314
VCID: 264D0245E877
Coding: 00030
Shop #: WSC 02314
VCID: 040978CD3E8B
Coding: 00204
Shop #: WSC 02314
VCID: 1E3D2AA5B027
Hi yah,
I can help with the following:
I can 100% say that a 65535 is a dead module, even a reset does NOT work, tried and failed. it is a simple replacement. I have just this weekend gone replaced my module after the same error. See this article, it is BRILLIANT.
https://www.audiworld.com/tech/elec179.shtml
Now this one is more interesting I have just replaced my EGT, with a "working" one and got this error AFTER the installation. Prior to a new senor going in I had a 17861, which sent me to this article, which is very good also.
If you find out anymore info please let me know:
https://www.audiworld.com/tech/eng73.shtml
As for the rest, sorry dont know.
BennieboyUK
BennieboyUK
