Wining noise from engine???
I have an 01 A6 2.7 that is making a loud wining noise from the front of the car.
The noise changes slightly with the engine RPMs, but not when the wheels are turned. It is loudest at idle, but noticibly different though when the car is put in gear. It is a bit louder when the hood is up
About a month before the noise started the car ran low on powersteering fluid. I took it to the dealer to make sure it was not leaking.
They said it was normal and only low on fluid. I had the system flushed to ensure no air or moisture. Could this be the power steering?
The noise started before the new waterpump was installed. It did not change after the work was done to the motor. (Timing belt, water pump, serpentine belt). The belt tensioners were replaced also on the timing and serpentine belts.
