30v Intake and PCV parts - paging 77'911 :)
#11
tank while the pump is running. You should be able to see it pissing into the tank if your tank isn't gunked up too badly. Pump is located in the engine valley, under the intake manifold. You'll be able to hear it with hood open if it's running. Faint humming noise.
#12
Expansion tank is no longer clear, but I reckon I could start the car and then shut it off and remove expansion tank's cap (before engine gets hot, coolant gets compressed) to see if it's pumping.
#13
often remembering things somewhat mixed at times. I do know I can hear the pump in the Passat w/ the ATQ engine after every shutdown - sure of that much.
audikillsbmw
07-16-2008 09:51 AM
GBW
06-17-2008 11:18 AM
x1rider
02-12-2007 05:19 PM
