ATQ deck height/piston stroke
Hello All,
I'm in the process of a top-end rebuild on a 2000 ATQ A6. In the process of cleaning the piston tops and deck surface, in preparation of putting the heads back on the engine, I noticed something very odd and disconcerting.
Number 1 piston does not travel to the top of the bore when rotating the engine by hand. All other pistons move to, or very near the top of the bore. When number 1 is at the top of it's stroke/bore there is ~ 3/32 of an inch of cylinder wall still visible. All other pistons, when at the top of their strokes, are near level to deck surface. Number 1 also goes that same distance deeper into the block bore. The carbon ring on the top ridge of cyl. 1 is visually wider than all other cylinders as well.
Any ideas? Is this somehow normal?
In 6 years of ownership there was never any indication of anything amiss internally.
Thanks for any response.
Hello All,
with an incorrect rod or piston? Do you have the warranty history?
rooster 2
05-15-2006 05:55 AM
FixedWing
08-25-2005 03:22 PM
Phat A6
10-07-2004 07:45 PM
Vesuvius
07-26-2001 05:10 PM
colorado audi
08-07-2000 06:58 AM
