Cam Tensioner Seals / Valve Cover Gaskets. Please Help!
Well I had a mechanic that was going to do the work for me, but he disappeared off the face of the earth. How difficult is this job? I'm pretty mechanically inclined, but after trying to yard the alternator out of this A4, I'm hesistant to even show a wrench to this car! Any advice, suggestions, DIY directions, and things to replace while in there is greatly appreciated.
Oh and the car in the sig is the car that needs the work. 99.5 A4 2.8 with 168k miles
Scott
Scott
I just had the TB job done about 10k miles ago by Redmond European in Washington. I started to have the seal problem shortly after the service, but they informed me that the seals that are leaking are not replaced during the timing belt change. I didn't like the sound of another 750.00 job after just having the TB job, all coolant hoses, alternator, tires, and brakes just recently replaced.
That's a really bad policy on their part. It's kinda like saying that the timing belt isn't broken so you don't need to replace it.
You'll have very little room to get to the seals with the belt in place. Unless you are very comfortable with your hands, get some help.
You will also need the special tool to compress the adjustor, about $20 i think.
Might want to replace spark plugs while you have some stuff out of the way.
here have a read of this<ul><li><a href="https://forums.audiworld.com/a4/msgs/1650707.phtml">Click</a></li></ul>
B1G-AL
04-05-2016 05:00 PM
constant maintenance
03-14-2007 06:25 AM
rushrx
05-19-2006 06:31 PM
