leak from oil pan
that requires some disassembly. Not sure if it means engine has to come out, but may be engine mounts need to be unbolted and/or subframe dropped. Upper oil pan leak ususally results in oil appearing on the tranny and at first glance seems like a possible RMS leak. If it is just oil on the lower pan where the temp sensor and drain plug is located, that is relatively simple. Good luck!
may want to get that. My guess is that there is a generic equivalent, but you never know with these cars - they tend to run a lot hotter than dometics and may require an especially robust sealant formulation.
in fact be a gasket, but they told me at the time that the revised fix was sealant on both. They have proven themselves liars in the past, so maybe this is not true. Just my experience.
Audifan1
10-19-2008 01:31 PM
RKA
21
03-15-2004 02:34 PM
a412banger
12v V6 Discussion
05-20-2003 07:18 AM
booker
03-03-2002 08:06 PM
