My 2.8 has a slight hesitation with fast acceleration from a stand still.
It is usually a result of a bad burn. Could be as simple as a bad tank of gas, fouled up plugs, dirty air or fuel filter or maybe a vacuum leak. Or maybe you throttle body is dirty. Either way, it is usually a result of a lean or (less likely) rich condition. Get a VAG, do some logging, see what you fuel trim, O2 and MAF readings are. This will give you the information you need to diagnose further.
also had the fuel injection cleaned with BG44k and some other stuff. Air filter is new, next thing on list is the fuel filter. No VAG as of now but thinking about it. What about the shadtree software. Vag is better?
My 99 2.8Q gave that feel from a stand still as well. I took it in to get diagnosed both by dealer and audi specialist. Result is throttle body valve is damaged. Dealer wants $800 for job. Part is $500 cdn spec order plus labour. I'm doing mine next spring when the A4 comes out of the garage. Again get some vags done and try to narrow it down.
orangedawg
04-09-2007 07:11 AM
Avantgarde
11
05-10-2006 08:20 AM
9490s33990
07-27-2004 05:16 AM
Blake@NWAutoSalon
10-11-2003 10:12 AM
