O2 Sensors
O2 Sensors
Where are the O2 sensors plugs on the 3.0? Specifically bank one side. I know the bright green plug is one but there arent anymore 4 pin plugs near it. I just want to know if its black 6 pin one to the left of it. Need to replace one.
Found all four plugs no fix for my issue yet (more info in post)
For reference
If you are in front of the car looking at the engine bay there are two plugs on the left and two on the right.
On the left (Bank 1)
There is a green plug with four pins
Two plugs to the left of that is a black plug with 6 pins
On the right (Bank 2)
You have to unscrew the coolant reservoir
There is brown plug with four pins
Two plugs to the right it is a black plug with six pins
The black plugs are pre cat (Sensor 1)
the colored plugs are post cat (Sensor 2)
But where are the o2 sensors?
I know this sounds like a stupid question, but I can't see or reach the front O2 sensors. How do you get to them to replace them?
The Bentley manual is worthless for this job. The BMW Bentley manual walks you through the whole job step by step.
i did them from underneath on my 2.8
not sure how different the 3.0 is but after you get the resovior off you should be able to see the exhaust pipe as it runs back toward the firewall. the passengers side one you can see if you take apart the intake ducting from the airbox to the throttle body.
it was a pain to get at either of them from the top because of the angle they face relative to the firewall.
i had a crows foot style O2 Sensor socket and about 18" of extentions so i could clear everything. i started the car up and let it run for a minute or two to heat up the pipe to make it easier to break free. took some fussing with and some burns on my knuckes but once you break em free from underneath you should be able to reach in from the top.
CalG
02-19-2007 06:56 AM
Kingttr
02-01-2006 02:39 PM
BluDemon
11-21-2004 02:58 PM
Mike'9390CS
09-29-2002 08:39 AM
