p1113 code 17521
#11
define 'manually'
here's my cheat sheet generated from the Bentley. I try to generate the 70 blocks first while the engine is cool enough
Generating Readiness Codes -
08 - Read Measuring Value Block.
04 - Basic Setting
60 - Block 60 Adapt OK Adaptation of throttle valve control module to ECM
30 - Block 30 Hold 1800 - 2200 until 111 Oxygen Sensor (O2S) control operating condition (bit 3)
34 - Block 34 Hold 1800 - 2200 until B1-S1 OK Oxygen sensor aging (time period) (bit 2)
35 - Block 35 Hold 1800 - 2200 until B2-S2 OK Oxygen sensor aging (time period) (bit 2)
46 - Block 46 Hold 1800 - 2200 until Cat B1 OK Three Way Catalytic Converter (TWC) diagnosis (bit 8)
47 - Block 47 Hold 1800 - 2200 until Cat B2 OK Three Way Catalytic Converter (TWC) diagnosis (bit 8)
70 - Block 70 idle until Evap OK Evaporative Emissions (EVAP) canister purge regulator valve diagnosis (bit 6)
71 - Block 71 idle until Syst OK Fuel tank leak detection (bit 6)
77 - Block 77 idle until Syst. OK Secondary Air Injection (AIR) system diagnosis (bit 5)
<b>
Readiness codes -
1 2 3 4 5 6 7 8</b>
...................0 Three Way Catalytic Converter (TWC)
................0 TWC heating (not applicable / always "0")
..............0 EVAP system and fuel tnk leak detection test
...........0 Secondary Air Injection (AIR) system
........0 Air conditioning system (diagnosis not applicable / always "0")
....0 Oxygen Sensor (O2S) control
..0 Oxygen Sensor (O2S) heating
0 Exhaust Recirculation (EGR) system (not applicable / always"0")
04 - Basic Setting
<b>
Readiness codes -
1 2 3 4 5 6 7 8</b>
RevPAR
06-06-2008 02:02 PM
Judge
12v V6 Discussion
15
05-19-2008 04:03 AM
tedmixis
2.7T V6 Discussion
01-08-2008 09:31 PM
CK NYoC
12v V6 Discussion
11-16-2007 09:41 AM
MarkFank
02-05-2007 05:58 PM
