please help fix my oil/coolant leak....
<center><img src="http://img.photobucket.com/albums/v355/gtipunk96/DSC_6860.jpg"></center><p>****!!!!
2.8 30v...
The engine was fully rebuilt, started and ran fine briefly. The car was moved outside the garage (started a 2nd time) and "milkshake" started pouring out. The P.O. got pissed and fed up and pushed the car outside and left it.....until I came along.
The car will start and run, but oil and coolant PUMPS out like a fire hose. I tore it down today and found that it is coming out of a hole located above the crank pulley....what is this hole?
2.8 30v...
<center><img src="http://i25.tinypic.com/24oomq9.jpg"></center><p>Looks like at a minimum, your missing one of the bolts for the upper oil sump cover, Was the metal gasket replaced with a new one? Most or all the hardware that hold that cover down are only torqued to 10Nm(7ft lbs.). You might consider stripping it back a little further.
The pic I put should give you a better idea of what the cover is like when most of the stuff around it is stripped away. Notice the bolt.
adminisTerTurbo
Audi Original "S" Cars
13
10-07-2008 04:32 PM
auto3251
12-06-2005 11:00 AM
bludvl
12-09-2003 04:17 AM
