Some questions.. Oil Leaks=$1,100 in parts and cam adjuster seals Valve cover seal
Well i got some work done on my Audi 2.8L V6 30v Leaking cam adjusters & valve cover seal. Now heres the question does the 99.5 come with a stock oil cooler? Does anyone no where i can buy a replacement stock breather filter? cause i have heard that a clogged breather can cause oil leaks. Also If anyone have any more insight on why Audi has such bad cam adjuster seals and valve cover seals please please tell me why Lord help me
<a href="https://forums.audiworld.com/a6/msgs/661880.phtml">Suction Pump</a>
<a href="https://forums.audiworld.com/a6/msgs/659100.phtml">Cam Adjuster Seals/Valve Cover Gaskets</a>
don't have the suction pump set up in the same way, at least that is what I recall. My wife has the 2.8L 30v w/tip and the suction pump; my S4 is manual w/2.7t which uses different PCV system design. I don't have a 2.8L manual for verification.
MYTTS
07-24-2006 06:06 PM
Bobby Kinstle
12-27-2003 01:07 PM
