Throttle body/DPF light engine management light
Hi all
I was wondering if anyone can advise me with my car problems.
A couple of days ago my engine management light came on, so I scanned it with a generic cable and got error P0638 throttle body actuator bank 1.
2 days after that my DPF light decided to show its face on the dash. I have read the owners manual and couldnt clear the light so I decided to buy a vag-com cable (expensive but worth it).
I was wondering if the DPF light and throttle body error could well be related?
I scanned the below error codes but dont really know what to make of them. Could some of the experts advise me please? I will apologise now for the long data message below.
There is also another error code in the below log which only vcds could detect, the error code is from a glow plug.
Thanks all...
Edit : Ok So I was able to get my car scanned with a vag-com cable the results are below
VCDS Version: Release 11.11.0 (x64)
Data version: 20111111
Tuesday,10,July,2012,19:52:28:37412
Chassis Type: 8T0
Scan: 01 03 05 06 07 08 09 0E 10 15 16 17 19 1E 36 37 42 46 47 52
53 55 56 57 77
VIN: WAUZZZ8T58A022238 Mileage: 178700km/111039miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAPA) Labels: 059-907-401-CAP.clb
Part No SW: 8K0 907 401 F HW: 8K0 907 401
Component: 3.0TDI EDC17 H01 0002
Revision: --H01---
Coding: 0114002C180F0118
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM30LTDIA5 A02002
ROD: EV_ECM30LTDIA5.rod
VCID: 2E597F1C710C5AE
2 Faults Found:
5308 - Throttle Body Actuator Bank 1 (J338)
P0638 00 [175] - Implausible Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 11
Mileage: 178564 km
Date: 2012.07.06
Time: 11:27:03
4986 - Glowplug for Cylinder 3 (Q12)
P161C 00 [047] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 178564 km
Date: 2012.07.06
Time: 11:28:53
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 N HW: 8K0 907 379 N
Component: ESP8 quattro H03 0210
Revision: -------- Serial number: --------------
Coding: 1B4500
VCID: 448D3DB4C780C0E
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 289 C HW: 8K0 907 289 C
Component: BCM2.01 H38 0253
Revision: 00003002
Coding: 031000
VCID: 39735C40B0428D6
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H34 0050
Subsystem 2 - Part No SW: 8K0 905 852 C HW: 8K0 905 852 C
Component: ELVAUDIB8 H35 0039
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 8T0 959 760 B HW: 8T0 959 760 B
Component: MEM-BFS H09 0043
Revision: AA000000 Serial number: 00001001049374
Coding: 08217025002444111000
VCID: 42813BACDD94CEE
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 F HW: 4E0 035 729 A
Component: Interfacebox H43 4690
Revision: 00000000 Serial number: 331KT077515644
Coding: 0005002
VCID: 3C7D45547F70B8E
Part No: 8T0 919 609
Component: E0380 BedienteilH08 0100
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T2 820 043 N HW: 8T2 820 043 N
Component: KLIMA 3 ZONEN H05 0120
Revision: D1000000 Serial number: 0112.11.070213
Coding: 36060000
VCID: 3D7B4850A46AB16
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H21 0253
Revision: 05021001 Serial number: 00000000054356
Coding: 260050910014AF010009000300005D5D0F1D03880001014100 0000
Shop #: WSC 00763 210 91830
VCID: 3065616463384CE
Subsystem 1 - Part No SW: 8T2 955 119 B HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 271007 H11 0040
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0002
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
1 Fault Found:
01496 - Bulb for Fog-Lamps; Left (L22)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 165
Mileage: 168428 km
Time Indication: 0
Date: 2012.01.18
Time: 12:53:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 8T2 035 110 B HW: 8T2 035 110 A
Component: MP3-Changer H42 0380
Revision: 00042002 Serial number: AUZ5ZBG4532141
Shop #: WSC 00000 000 00000
VCID: 2A51730C85E436E
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 C HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0010
Revision: 11001001 Serial number: 75230732507851
Coding: 100001
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H23 0409
Serial number: 0038JD11EB4V
Coding: 30323433363030303030554A305238543053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02001
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3C7D4554B770B8E
Crash sensor for side airbag; driver side:
Serial number: 6334MSME31510E7DH
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME32024C186
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME46224569F
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME462431198
Crash sensor for front airbag; driver side:
Serial number: 63732SME427A496B9
Crash sensor for front airbag; passenger side:
Serial number: 63832SME3D702E433
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H10 0012
Revision: -------- Serial number: 90304GK800090
Coding: 000016
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 981 B HW: 8T0 920 981 B
Component: KOMBIINSTR. H28 0214
Revision: 00100000 Serial number: 71Y15AUA7
Coding: 2F05010002002600010000
VCID: 3B7F4648BA7EBF6
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 F HW: 8T0 907 468 F
Component: GW-BEM 4CAN-M H07 0084
Revision: EB002032 Serial number: 3200E07A178202
Coding: 000003
Shop #: WSC 00565 210 66245
Subsystem 1 - Part No SW: 8K0 915 181 HW: 8K0 915 181
Component: J367-BDM H06 0150
Address 1E: Media Player 2 (R192) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H15 0700
Revision: 00000000
VCID: 27578A3856F60B6
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H09 0043
Revision: AA000000 Serial number: 00001001049315
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 T HW: 4E0 919 887 M
Component: MNS ECE H50 1030
Revision: 00000000 Serial number: 333KZ077526907
VCID: 3E794F5C696CAAE
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 HW: 8K0 959 793
Component: TSG FA H09 0149
Revision: Serial number: Gxf
Coding: 011C022250012201
VCID: FDFB085064EAF16
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00003002 Serial number: 0107600570
Coding: 011B0682003904C0002000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0030
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Address 47: Sound System (J525) Labels: 8T0-035-223-ASM.clb
Part No SW: 8T0 035 223 P HW: 8T0 035 223 A
Component: DSP STD H07 0250
Revision: S2400000
Coding: 010101
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 HW: 8K0 959 792
Component: TSG BF H09 0149
Revision: Serial number: Tvf
VCID: FCFD05547FF0F8E
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 C HW: 8K0 907 801 C
Component: EPB Audi B8 H03 0040
Revision: 00000003 Serial number: 00000000033519
VCID: 2F6762187E06536
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 A
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000002
VCID: 336F6E68522E776
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 336KZ077525284
Coding: 0000001
VCID: 2E597F1CB90C5AE
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 C HW: 4E0 919 148
Component: R0078 TVhybridTuner 0400
Revision: R0H06000 Serial number: 76300800993402
Coding: 0000203
VCID: 234F9E28E2CEE76
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 C HW: 4F1 862 335
Component: BTA H10 0960
Revision: 00H10000 Serial number: 00000007547297
Coding: 0010021
VCID: 244D9D34E7C0E0E
End ---------------------------------------------------------------------
Does this mean anything to anyone? It certainly doesnt here.
I also managed to pull off some further info on the DPF.
20:35:56
0.00 % Air conditioner fan activation 006
279.6 mg/stroke Specified air mass 007
0.00 % EGR valve feedback 033
6 hPa Particul.filter diff.pressure 071
33.2 degC Exhaust gas temperature before particulate filter 074
18.5 degC Coolant temperature at radiator outlet 075
-0.34 mg/stroke Cylinder 3 injection quantity variation 081
28.04 g Soot mass measured 118
33.02 g Soot mass calculated 119
Any advice would be thoroughly appreciated.
Thanks all...
Chassis Type: 8T0
53 55 56 57 77
Revision: --H01---
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Mileage: 178564 km
Date: 2012.07.06
Time: 11:27:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 178564 km
Date: 2012.07.06
Time: 11:28:53
Coding: 1B4500
Revision: 00003002
Coding: 031000
Coding: 0005002
Coding: 36060000
Coding: 00FD11
Coding: 02532C
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 165
Mileage: 168428 km
Time Indication: 0
Date: 2012.01.18
Time: 12:53:00
Coding: 100001
Coding: 000016
Coding: 000003
Revision: 00000000
Revision: S2400000
Coding: 010101
Coding: 0000002
Coding: 0000001
Coding: 0000203
Coding: 0010021
20:35:56
LUCIFA
04-17-2002 02:53 PM
