Velocity stack available still? Is UrS4 still doing them?
I've sent e-mail to his e-mail address that I had but I think that and /or his Audiworld user name changed, feed back anyone?
From what I understand it's an original UrS4 stack. If you can't find one anywhere I could talk to Rick and see if he would be willing to sell/give you this one.
great ,because I haven't been able to get in contact with him on here or e-mail.I'm pretty sure he has changed his name on here,but unsure what he goes by now. Let me know if you can find/sell that one,I'm interested.
He's not the original maker of these stacks, he's just an owner of this particular one. I can't use it in my setup and it's my understanding that he can't use it either, but I'll let you know for sure.
The email address I have for him is the same as on here. Last I heard, he's still making stuff but in a limited fashion. If you email him, put something about "AUDI" in the subject line or it gets filtered unread. I'm loathe to part with the VS since it is an easy way to cut 30 g/s off the MAF flow and if I no longer had it, my 30# injectors would be totally worthless. What do you hope to accomplish with the VS? Do you have a Stage 3 MAF? The velocity stack will not fit properly with the stock MAF housing unless it is de-screened or the VS is cut down length wise. Just curious.
That's a bummer you can't use it on your setup, I guess a G2 could use it though. I just installed my MAF and VS a week ago, happy with the results. I bet it'd be even better running GIAC software, hmmmm.
I'm running a cone connected directly to the S3 MAF. That's as good as it gets, the only restriction is the supercharger intake itself rather then the intake piping.
Thanks ,My plan is to add VS ( remove screen)along with a smooth stainless tube and connectors(1 straight/1 turbo style hump hose) between modified MAF and TB.I was going to add these when I chip the car within the next yr.Have access to TB though wrecking yd contacts.Have 3 inch stainless and connectors gathering dust for 4 months now,too many other projects at home.Had e-mailed twice with no reply ,thanks for the info.
also with all the mods you have do you think you have over 220 hp at crank or have you dyno'd it?
