A6 4.2 '99 Vacuum issue??
Old 09-25-2008, 10:24 PM
  #11
Member
audikillsbmw's Avatar
Ah.. I forgot that you're across the pond. They might not require stickers over there.
Old 09-26-2008, 09:21 AM
  #12
Member
Default Try checking your intake setup for leaks, starting right after the MAF sensor.
Also make sure to check the intake manifold itself. The first time I removed mine, almost all of the bolts holding it down were loose.
Old 09-28-2008, 10:50 AM
  #13
IanManchester's Avatar
Default UPDATE
Audikillsbmw, you were quite right about the MAF sensor, I took the car to an VW Audi specialist, the checked the vacuum pipes no problems. Turned out to the be MAF sensor - they swapped that with the new part and now the car seem to run perfectly. The garage said there were no more fault codes - (I havent check on VAGcom yet).
Kaynos - Make sure that you get your MAF from Audi dealer only - my specialist replaced it initally with a bosch part and it didnt fix the problem.
Thanks for everyone helping. :-)
Old 09-28-2008, 10:55 AM
  #14
Default Re: UPDATE
Just got to sort out my headlight leveling and the cars fault free. - before any asks I have changed the sensor.
Old 10-03-2008, 09:36 AM
  #15
Member
Default I'm also getting a lean code right now, and it's keeping me from passing my emissions test : (
I just picked up a new fuel filter and MAF assembly. Hopefully that will solve the problem..
Bay M
04-28-2014 05:49 AM
hanshy5
12-01-2008 11:34 PM
IanManchester
VAG-COM Discussion
09-13-2008 07:06 AM
apru
10-10-2005 07:44 AM
Felk_2.7T
13
05-31-2004 07:38 PM
Quick Reply: A6 4.2 '99 Vacuum issue??
