ECM failure?
ECM failure?
Our 2008 4.2L Q7 all of a sudden has started running very rough (still starts) and has a ton of error codes. This just happened all of a sudden, so it seems one of these codes is the real problem and rest are just related issues. I'm assuming it's the ECM and I need to replace it? Thoughts?
00135 Fuel rail system pressure too low
08852 Fuel pressure regulator 2 control circuit
00768 random/multiple cylinder misfire detected
00776 cylinder eight misfire detected
00774 cylinder six misfire detected
0101112 evaporative in mission system the purge control valve circuit low
05173 secondary air injection pump relay J299 short circuit to ground
05153 secondary air inlet valve N1 12 short circuit to ground
05255 Secondary air injection secondary air injection valve 2 N3 20 short circuit to ground
00258 mass or volume airflow circ low input
00268 mass or volume air flow B circuit low input
04763 fuel pressure regulator valve bank to open circuit
01314 engine control module ECM - please read DTC
BrianC72gt
VAG-COM Discussion
03-29-2014 12:31 PM
s4indaworks
27
01-24-2004 04:49 PM
fredfromny
03-25-2002 06:15 AM
