I'm dissapointed w/my 2005.5 V8 engine, what can I do to improve?
#12
The crapy compression on YouTube sucks, if it catches your eye though you can download the full version on my website at
http://www.brittcrowell.com/2005/A8%20Dexter%20to%20lake%205x%20with%20audio.avi
You need the Divx codec and its about 30MB
Britt
BTW my A8 will do 1/4 in:
14.49sec @ 101.8mph 0-60 6.12sec
after tranny recode and fixing my intake leak<ul><li><a href="http://www.youtube.com/watch?v=1vIXFxaWwHk">http://www.youtube.com/watch?v=1vIXFxaWwHk</a</li></ul>
Britt
#14
I know that I'm going to get a beating for this newbie question...but here goes... I've got an 07 A6 4.2 s-line on order and am interested in giving it a bit more. Your 3 phase plan sounds great but it's also a little greek to me. Could you possibly give a little more detail and your gut feel for the performance improvement? I'd greatly appreciate it.
What is I/E/DPs? I assume exhaust and downpipes. APR claims a 25hp/35lb-ft of improvment. For roughly $2500, it seems like a great investment.
I understand the chip improvments. GIACs chips probably going to run $1K after install and get me 10hp at best. DO you have a recommendation on vendor?
now on to the third phase and here's where you lost me....
What's a valve job get me? Better seating? What's the benefit? $348 seems cheap for ripping the head off.
Ditto on the R&R...absolutely no clue what this is...(I did say that I was a newbie)
Any recommendations on the cam and/or timing?
I've heard the lightweight clutch was a good to do. How about the rear differential? Any benefit to adding a limited slip differential? I know it's not an engine discussion but...
Sorry for the long post but any reply would be very useful.
#17
I/E/Dp is Intake, Exhaust, and down pipes it's usually the first step in performing your basic performance upgrades; (BPU) from there is a chip. APR is about $500 you want to call them to find a local distro.
Once you've done all the above you can focus on doing the light weight mods..I've removed the spare tire and bought a super light odyssey battery. Since I had to do engine work I'm doing the head work. But I would recommend some light wheels, suspension, and brakes which for me personally I have experienced to be the biggest bang for my buck, BUT they cost the BIGGEST BUCKS. Something like a 17x7 Velox PG-Rev10 that are 11.5lbs per wheel, with lighter suspension and brakes make a huge difference in ALL depts. acceleration, handling, stopping and of course weight.
Timing is handled by the chip, now the cam was the only item I changed my mind on because after installing the cam the ECU would need to be tuned and you're opening a whole new can of worms. better to say on the path than blaze a new one. (none of the chip manuf. have a program for the cam) The piston and valve paths "interfere" with one another (known are an "interference head") so having a cam that had a longer lift or duration may cause a catastrophic engine failure when the chip advances the timing.
I'm having trouble finding the lighter clutch flywheel...when I got it over to the shop the stock unit was completly different from what they thought. So i'm exploring other options. as for a rear limited diff...I would probably not do anything with it unless you've done everything else (including a supercharger) and you're really tracking the car and you can get any speed out of the corners.
yourk
09-30-2003 11:29 AM
