o2 a8l power steering pump howling
first to see if that helps - <a href="http://www.audipages.com/Tech_Articles/susp_whls_brake_steer/psflush.html">Power Steering Flush Procedure</a>. Otherwise you may need a new pump, or better yet, buy a rebuild kit and do it yourself for a lot less (if you are mechanically inclined). One question though, I had what I thought a PS pump whine and it turned out to be a bad AC cooling fan. When the car is running, press the ECON button on your climate control unit and see if the noise stops. Doing this turns the AC cooling fan off. If there is no noise, then the bearings in the electric fan went bad and it will need to be replaced.
Just wondering if it would be worth doing as a nice little DIY project.
Please, let me know if I'm going to end up ripping my hair out!![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
Thanks!
Thanks!
site (<a href="http://www.pskits.com">PSKits.com</a>) where I ordered my A6 kit, and see that they only have one for a 97 A8. :-( There's gotta be one somewhere! I have yet to rebuild mine, but from what I've heard, it's not too difficult.
WOW, that's pretty funny. All the 1987 through 1994 5000, 200, V8 cars take basically the same kits, and you can get the kits from AutohausAZ for around $6. The pumps differ slightly, but the internals are the same. These guys charge over $40 for the same set of seals.
find one for the our kind of pump. I thought PSKits.com had a kit for the A8, which they do, but just for a '97(!). I cannot find anything for our ZF pump. Very interesting indeed...
Kris Hansen
08-01-2012 04:19 AM
tej
01-19-2001 07:51 AM
