P&P and 5 angle valve job
Old 06-20-2006, 12:33 PM
ub2slw's Avatar
Default P&P and 5 angle valve job
I should get about a 10-15hp gain
<img src="http://pictureposter.audiworld.com/85119/101_2714.jpg">
<img src="http://pictureposter.audiworld.com/85119/101_2711.jpg">
<img src="http://pictureposter.audiworld.com/85119/101_2710.jpg">
Old 06-22-2006, 03:29 PM
tozoM8's Avatar
Looking good.
Old 06-22-2006, 05:06 PM
kwb
New Member
kwb's Avatar
Default Newbie question
can you give a little more detail on what this mod exactly is?
Old 06-23-2006, 11:51 AM
ub2slw's Avatar
Default Re: answers...
P&amp;P=Port and Polish
The porting increases flow by reshaping and enlarging the intake and exhust tracts by cutting away at the side walls. The polishing smooths the surface walls to increase flow and reduce the build up of combustion deposits on the exhaust side. On the intake side there's a "rough" polish which helps mix the air and fuel before it enters the combustion chamber. So in theory the atomized fuel burns better resulting in more horsepower and better fuel economy.
<img src="http://pictureposter.audiworld.com/85119/untitled.jpg">
The five angle valve job also improves air flow by cutting the seat and the valve. The added benifit is a tighter seal so less leak down. (they acutally pour water with the valves in the head to ensure a tight seal)
<img src="http://pictureposter.audiworld.com/85119/untitled2.jpg">
Old 06-23-2006, 01:39 PM
New Member
B'allRoad's Avatar
Would you be willing to tell us how much this cost?
Old 06-23-2006, 02:03 PM
ub2slw's Avatar
Default Re: cost breakdown
Well besides a voided powertrain warranty..
Valve Job = $350
P&amp;P = $500
Head Assembly = $148
Engine R&amp;R = $3,000
Old 06-26-2006, 07:09 AM
kwb
New Member
kwb's Avatar
Thanks for sharing, ub2slw. Excellent post.
Old 06-26-2006, 07:12 AM
kwb
New Member
kwb's Avatar
Does Engine R&amp;R translate as removal and reassembly?
Old 06-26-2006, 10:40 AM
ub2slw's Avatar
close....Removal &amp; Reinstallation
Old 06-27-2006, 03:48 PM
Ron5oh's Avatar
What model car is this going on??? Nice work...what shop did it?
Quick Reply: P&P and 5 angle valve job
