Removing 2004 S4 Engine???
Just brought home a mint 04' S4 with the Tiptronic transmission. Previous owner said the #6 injector stuck and washed the cylinder down 30psi. He then replaced that injector and drove another 1500 miles until a rod bearing went. So Im getting ready to pull the engine out but not sure what the best way to do that is. Pull out just the engine? Engine and trans? Drop down the entire engine cradle? I have a two post hoist so have a few options. Any help would be greatly appreciated. Thanks!!
Easiest way I do audi engines is, remove the front clip, and pull it out the front. Some cars you have to remove engine and transmission together as there is not enough room to get to all the bolts.
uble1234
14
10-23-2020 08:07 PM
Monsoonenough
S4 (B8 Platform) Discussion
10-03-2015 02:59 PM
kevjo55
09-30-2015 08:02 AM
