Strange knocking from passenger / rear over sharp bumps
Head Cat Herder
![](https://www.audiworld.com/forums/images/ranks/admin.jpg)
![](https://www.audiworld.com/forums/images/ranks/editor.jpg)
My '14 allroad has developed a strange noise from the right rear that can only be described as a knock, It does not happen over every bump, and it happens most when only the right rear hits the bump. Seems like a sway bar issue, though on inspection everything is tight and intact.
to my ears it sounds like either a worn ball joint, or a loose shock mount. Again, it only happens on very sharp bumps. I would say it sounds like there's a golf ball banging on stuff, but there isn't. I drove it with everything removed from the trunk (even the tools, jack, tire, compressor, side panels and roll cover) and it still made the noise.
Head Cat Herder
Figured it out - the bump stop on the right rear shock wasn't staying up in it's place in the upper shock mount. Gave it a little wrap with some electrician's tape, and it's holding in place. No more crazy noises.
KillA6
13
04-04-2007 10:39 PM
roadyTT
11-05-2006 05:40 PM
tmorales
12-04-2002 07:36 AM
