Allroad wheelsize 20"
I'm look for a new set of wheel for my 2017 allroad and wanting to know if the following wheel and tire will work.
please kindly advice if spacer or no spacer is needed.
http://www.ebay.com/itm/20-inch-1196-Style-Wheels-Gunmetal-Machined-Fits-Audi-A4-A5-A6-A7-TT-VW-Rims-/152447605425?vxp=mtr&hash=item237e95dab1
please also advise if spacer or no spacer is needed
Thank you for your reply! I'm guessing no spacer will be needed.
I am debating if I should lower it, I really want to make it look like the rs4. I will have to see how it would look if I put the 20" on. Will it look low enough..
Not needed but will look better with it. Those wheels will be sucked inside the fender.
Allroads have the fender extensions so you can fit wider wheels than a regular sedan/avant.
I have the same spec wheels on my b8.5 allroad(similar if not identical fitment to the b9) and I have 20mm spacers.
B8/B8.5 didn't have the adaptive suspension and dampening though right? I'm thinking of putting the A4 Avant Adaptive Dampening Sport Suspension on the B9 but can't confirm how much of a drop that's going to provide as of yet since I do t think anyone ha done it yet (stateside at least).
All guesses lol...
I think the avant s-line is about 1" lower than a regular avant?
I think the allroad is about 1.5" higher than an regular avant.
Add that up and it's at least a 2" drop while keeping everything OEM.
If you can find a B9 s-line A4 avant suspension, that would be a great swap. I am guessing you would have to source it from Europe?
