OEM hitch options?
#81
Just resurrecting this thread to ask whether or not anybody has installed the Stealth Hitch yet on a B9 allroad? I believe that one or more of the Stealth Hitch employees used to be involved with Invisihitch, and the Stealth Hitch is basically the same design as the Invisihitch. I installed an Invisihitch on an XC90 myself and it turned out pretty well, so I'm hopeful that the B9 allroad Stealth Hitch will be similar. If you did install a Stealth Hitch, what did you use for wiring?
https://stealthhitches.com/products/...itch-2017-2020
EDIT: Never mind - I found the answer here, although this thread only contains posts from the manufacturer:
https://www.audiworld.com/forums/a4-...views-2956693/
Also see these threads:
https://www.audiworld.com/forums/a4-...iting-2939328/
https://www.audiworld.com/forums/a4-...hitch-2971853/
I'm still unclear about the wiring, as the only wiring harnesses discussed in those threads were sourced from Invisihitch and a few people had trouble connecting them successfully.
SDakota (08-18-2020)
allroadCole
Audi allroad
22
02-14-2007 02:30 PM
Ed@mtl
Canadian Discussion
03-14-2003 10:43 AM
