[axle heat shield]- I can't get the middle bolt off the shield.. any tricks?
I have been trying for over an hour to get the middle bolt off the heat shield to the axle. The reason I need to get the shield bolt off.. is to gain access to the 3 cat bolts, so I can remove my exhaust. Is there a special tool I can use? thanks.
I'm kinda stuck, since I need to remove the heat shield to get to the cat bolts.. any ideas are greatly appreciated, thanks.
I forget which it is. Either way, you'll need those. Then you can use a long extension and a socket wrench. Either wedge yourself up in the wheel well or take the tire off, then you can see and directly get to it.
Those crazy bent wrenches will help here. So will a u-joint socket adaptor. You'll want many different length socket extensions. You only need to get a wrench on the lower nut. The top bolt is welded in (or at least tight enough not to counter hold) so don't worry about the top. Just hit the bottom. Spray the hell out of each with penatrant. Because of the tight space, you'll only be able to turn each about 5 degrees each time. That's why the cat bolts suck. Just think, it's a good forearm workout.
i picked up some extensions today, 24", 10", 8", and a 3". Hopefully I have enough sizes. I assume you just use a 'swivel' adapter to get the sockets on the cat bolts properly.
I should get the bolt off with the 6mm hex socket + an extension, using a breaker bar. The other part I don't have is the 'swivel' adapter for the cat bolts, which I will get tommorow. I picked up a 24", 10", and 8" extensions today, is there anything else I would need? Thanks for the help man.
In case you don't know the trick...
You'll see that you are forced to use wrenches to get the cat bolt off, in very tight spaces. A good trick for this in to interlock an additional wrench. You may already know this trick, but it is not obvious if you don't. Put the correct wrench on the bolt. To get the torque you need, take another wrench and interlock the opposing side into the end of that wrench (play with it, you'll figure out how). This will help immensely to get those damn cat bolts out.
I didn't think I would have to with the sockets, but you bring up a great point.. lack of space to move. I will definately try this tommorow when taking the bolts off, thanks buddy.
S4 in_lowplaces
19
01-30-2008 04:18 AM
Vegito@BostonAudi
12-27-2002 10:06 AM
Object
10-11-2001 04:25 PM
