1.8t crank but no start need help ASAP
Hello everybody
well yesterday evening the car was driving and all was good I got back home park the car in the drive way and in the morning the car crank but refuses to start up tried to spray this spray for starting the car to the intake but no success there, connected vag-com found no code. What else can go bad and how to check it
Please I need the car running as it’s my only car (by the way it’s 2002 A6 with 1.8T European ver.)
Any ideas are more than welcome; please let me know if you need any more info
If you do the correct method and no-start, then suspect ignition.
you can also pull the spark plugs and see if they are wet? and then if it has spark.
obviously you need fuel, air and spark. does the car smell like Gas? if it smells and the plugs are wet you could have bad leaky injectors and fouled plugs, although this is not at all a common problem so I doubt this will be your problem. but you need to check the plugs and spark and fuel....
hi everybody i really appreciate the help of all of you well i did some of the tests and here is the results :
speed sensor: ok
spark: ok
fuel pump: didn't hear its starting so removed the cover in the trunk disconnected the electrical connection and discovered when key is out it receive about 3V when cranking 12V
so by the look of thing looks like the fuel pump is bad but what i cant understand is why the car doesn't start when is spry into the intake manifold
any ideas
speed sensor: ok
spark: ok
any ideas
speed sensor: ok
spark: ok
any ideas
speed sensor: ok
spark: ok
any ideas
