When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
I need a head for my AWM, I can not seem to find one around here but see plenty of AEB and even an AUG. What would the easiest path be to get back on the road, and what components would I need to swap (cams, manifolds, tensioners...)?
I might have an AWM head. What is wrong with yours?
Mine has a few bent valves. Been meaning to get the valves replaced and use it for a spare, but I'd sell it as is or fixed, your choice if you are interested.
I have no details (not my) garage (out of state) tells me their machine shop said it was cracked. I am picking it up and taking it to my machine shop Monday. I take it you lost a timing belt, did you get the head checked? PM me on $$ and your location.
You want to swap everything you can. Problem is the AEB/AUG heads do not have a SAI port and they also have larger intake/exhaust ports. The exhaust ports are not an issue, but you will want to get a tapered intake gasket if you plan on running your AWM intake manifold.
Any specifics on what needs to be done to put AEB, AUG or any other available head where my AWM was? Should I do things like replace my intake manifold, I thought I read with some heads I need to use the original exhaust cam...things like that.
Thanks in advance.
Not the cam you need to use, its the cam pulley that the timing belt goes on. You need to use the cam gear that is made for the engine you are running since it is part of the timing belt system.
I swapped my AEB head to my APH head on AEB block because I had the APH head ported and polished awhile back, its ports are actually now bigger than the AEB head. so I imagine you can swap any 1.8t head to any 1.8t block or visa versa. I had to use 7/16" drill bit to bore the head bolt holes on the aph head for the aeb arp head studs.
I forgot to mention. that picture of the APH camshaft position sensor is before I swapped it to the AEB sensor. do not forget to swap these as the ecu will not read the cam shaft position correctly!!
