1.8T vacuum tubing diagram despirately needed!
Hello. Can somebody please e-mail me with the vacuum tubing diagram for a '97 A4 1.8T. I'm removing my boost controller and trying to hook the vacuum tubing up to the stock configuration so I can run with a chip. I need a diagram for the turbo and blow off valve hook up to the engine and car. Thanks a lot!
<center><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/Vaclayout.gif"></center><p>Hope this helps...I assume this is what you were looking for???
1-EVAP canister
2-From fuel tank
3-Evaporative Emission (EVAP) canister purge regulator valve -N80-
4-Check-valve for EVAP canister
Between EVAP canister and intake manifold before turbocharger
Installation position (light/dark side): Arrow points in direction of flow, as shown
5-Air cleaner
6-Turbocharger
Check boost pressure page 21-46
7-Combination valve for secondary air injection (AIR)
8-Fuel pressure regulator
9-To power brake booster
10-Check valve
11-Vacuum booster
12-To Leak Detection Pump (LDP)
13-Vacuum reservoir
14-Distributor piece
15-Check valve
16-Secondary Air Injection (AIR) solenoid valve -N112-
17-Crankcase vent
18-Check valve
19-To tank Leak Detection Pump (LDP) -V144-
20-Check valve
21-Charge air cooler
With charge air pressure sensor -G31-
22-Throttle valve control module -J338-
23-Recirculating valve for turbocharger -N249-
Checking page 21-40
24-Intake manifold
With Intake Air Temperature (IAT) sensor -G42
25-Pressure unit for boost pressure regulation
26-Wastegate bypass regulator valve -N75-
27-Mechanical recirculation valve
Checking page 21-38
28-Pressure control valve for crankcase ventilation
29-Secondary Air Injection (AIR) pump motor -V101-
Regards,
James R.
2001 A4 1.8TQMSX-ESP On order, arrives Sept/Oct if I'm lucky.
For sale 24,500 all mods listed plus all orig parts including turbo included in this price.
99 1.8TMS (Neuspeed K04, 5 Bar FPR, Beru Ultra X Plugs, K&N Filter, Remus Exhaust, S4 Wheel Well Liner Mod, Bilstein Sport Shocks, Neuspeed Sport Springs, Neuspeed Front Anti Sway, Brembo Rotors, Mintex Red Box, Ronal R-7's 17", 225/45/R17 Bridgestone S02 PP, Smartire (neat gimmick), Greddy Turbo Timer, European Projectors, Clear Sides and Full Tint...)<p>
1-EVAP canister
2-From fuel tank
5-Air cleaner
6-Turbocharger
10-Check valve
11-Vacuum booster
13-Vacuum reservoir
15-Check valve
17-Crankcase vent
18-Check valve
20-Check valve
Checking page 21-40
24-Intake manifold
Checking page 21-38
Regards,
James R.
James-
Where do you get this great stuff from? This is awesome. By chance, do you have the ECU maps for the 1.8t? I need the maps eventually to hook up my A'PEXi Super AVC-R boost controller. Mostly need the maps to hook up the RPM monitor (I think). Thanks again!
ipsodox
Audi A3 / S3 / RS 3
07-26-2011 06:40 PM
millertimeFL
03-03-2005 08:45 AM
NeverEnough
11
03-08-2004 06:20 PM
