100w super white xenon gas bulbs by APC
I just went to Zeke's Custom Auto in N. Dighton, MA today.
I bought a pair of H7 100w super white xenon gas bulbs by APC for $50. Have any of you heard of these? I'm using them for the high beams and hope I don't burn something out. Zeke's saleman says these have a life time warranty against burnout as long a the glass bulb isn't broken and I have the sales slip.
I took my car out tonight for a test drive and was quit impressed (with 100w bulbs I shouldn't be surprised). Very very white with excellent range. I'll have to check if 70w bulbs for the lows and fogs are available as well.<ul><li><a href="http://www.zekescustomauto.com">http://www.zekescustomauto.com</a</li></ul>
100watt bulbs may burn out your light switch at the steering wheel (dont ask me how I know this).
You must add a second bosch relay and some heavy wire to run those safely<ul><li><a href="http://www.turbo5.com">http://www.turbo5.com</a</li></ul>
i have a 97' so the fog lights are in the same unit with the low and high beams. H7 for low and high beam, H1 for fog light beam. If you have a newer model than the size should be all H7, but be careful what brand you buy, some of the brands 100w bulbs are fatter than the stock bulb so don't fit in the projectors or the fogs. you should check.
dA4banger.au
02-10-2003 05:37 PM
98 Avant
02-03-2000 05:17 PM
