18" wheels on B5 A4 Avant fitment
I have a 98 A4Q Avant and need to know if an 18x8 wheel with 35mm offset will fit ok. Are there any clearance issues i need to worry about? I know the bolt pattern is ok... anything else to worry about? Thanks!!
I do have Eibach Sport springs so it is lowered a bit from stock. Will that be an issue?
less than the 235's did. Your wheels are ET 35 though so you should be perfect, mine are just a touch too far out, enough to rub some
4driver4 is right about the rotational mass though. My 18x8 RS4 reps are far heavier than the stock 16" sport wheels. It is actually noticably slower (or faster depending on which switching from/too) when I swap the larger wheels on the car. It is also more unsprung weight, so the car will handle slightly worse over bumps (not to mention will feel worse because reduced side wall)
Even considering the above concerns, I still love my 18x8 RS4 reps and run them 8 months out of the year.
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
myaudi_a4wagon
02-25-2008 03:06 PM
S4Ca$hwhore
11
01-21-2007 09:24 AM
ThunderGrey27OffSuit
Mid Atlantic Discussion
12-09-2005 01:38 PM
