1996 a4 1800 engine 20 valve, no turbo_Cyl Head Bolts Specs
Can any one give me the specifications for the
cylinder head bolts. I need the length, the thread pitch and the diameter. Quote the size in
millimeters please.Also which other Auto Manufacturer uses the same size bolts.
Cylinder Head Bolts Specs,
For all you smart ones out there who think I dont know what I want; here is the answer.
Bolt length 96 mm, width 11 mm and thread pitch
1.5 mm. (Thread pitch means the distance between the thread crest when you turn the bolt 360 degrees.Do you know that Many VW parts are interchaneable with Audi parts huh!same stuff just less expensive.
AMorris
11-12-2005 11:59 AM
