1996 Climate Control problems
The climate control 'partially' works (fan, control unit, air vents, etc) but it does NOT get really warm.
The scan shows the following codes (below).
Where should I start with the troubleshooting. Someone told me NOT to jump at replacing the module yet.
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOMAT_D75
Coding: 04162
Shop #: WSC 06325
VCID: 29570979F97F
6 Faults Found:
00792 - A/C Pressure Switch (F129)
31-00 - Open or Short to Ground
00532 - Supply Voltage B+
07-00 - Signal too Low
01297 - Sensor for Vent Temperature; Footwell (G192)
30-00 - Open or Short to Plus
01296 - Sensor for Vent Temperature; Center (G191)
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
01582 - Signal for Coolant Temperature
Coding: 04162
Shop #: WSC 06325
VCID: 29570979F97F
6 Faults Found:
