1997 A4 2.8 Running like garbage
Was driving down the interstae and everything was fine then car started run like garbage(No throttle response). Car wont go over 20mph, but got me a few miles home. Starts and ideles fine then when I give it gas in neutral starts missfireing and wont got over like 3k RPM. Pulled the codes and this is what I got. Where do I begin,
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Mileage: 289440km/179849miles
Address 01: Engine Labels: None
Part No: 8D0 906 266 B
Component: 2,8l V6/2V MPI OBD2 D01
Coding: 01251
Shop #: WSC 20205
3 Faults Found:
17914 - Throttle Idle Switch (F60): Does not Open or Short to Ground
P1506 - 92-00 - Unknown Error Elaboration
16504 - Throttle Position Sensor (G69): Circuit Malfunction
P0120 - 92-00 - Unknown Error Elaboration
16525 - Oxygen (Lambda) Sensor B1 S2; Heating Circuit: Malfunction
P0141 - 92-00 - Unknown Error Elaboration
Readiness: N/A
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8D0 927 156 J
Component: AG5 01V 2.8l2V US D9B
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 03: ABS Brakes Labels: 4D0-907-379-ABS.lbl
Part No: 4D0 907 379 L
Component: ABS/EDS BOSCH 5 4171
Shop #: BB 34171
No fault code found.
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 B
Component: A4 KLIMAVOLLAUTOMAT_D72
Coding: 04162
Shop #: WSC 06335
Address 15: Airbags Labels: 8A0-959-655.lbl
Part No: 8A0 959 655 D
Component: Airbag V AUDI D00
Coding: 00127
Shop #: WSC 06325
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 8D0-919-0xx-17.lbl
Part No: 8D0 919 036
Component: B5_KOMBIINSTRUMENT D09
Coding: 00262
Shop #: WSC 36099
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8LO 862 257 B
Component: CV-Pump,Alarm, RC
Coding: 12236
Shop #: WSC 65535
3 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
End ---------------------------------------------------------------------
After Clearing all the codes and just starting the car and letting it run in neutral and push the throttle a little these are the codes that it threw...
P0102 - Mass Air Flow Sensor (G70): Signal too Low
P0120 - Throttle Position Sensor (G69): Circuit Malfunction
Any help would be appreciated.
Coding: 01251
Shop #: WSC 20205
3 Faults Found:
Readiness: N/A
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
Shop #: BB 34171
Coding: 04162
Shop #: WSC 06335
Coding: 00127
Shop #: WSC 06325
1 Fault Found:
Coding: 00262
Shop #: WSC 36099
Coding: 12236
Shop #: WSC 65535
3 Faults Found:
35-00 - -
35-00 - -
35-00 - -
The MAF and TPS both ground at the same place, so I'd check the brown/black wires at each connector: you want low resistance to ground. The Throttle connector is at the bottom of the throttle body, so it's not convenient to reach. The fact that something happened all of the sudden with these two codes makes it likely that something electrical and common to both is the reason, and besides the ground, both connect to the ECU. This is a good time to find all ground connectors, including the main battery ground, and clean/lube them.
Next time you scan it, run the engine and watch the mass air flow and throttle-angle, see that these increase when you push the gas.
At least your car got you home; Mine died on the freeway last week (I posted about it), 187,000 and the fuel pump quit.
S4MarkS4
11-06-2006 02:41 PM
