1997 A4. Radio not working
Next thing to check is to see if the hot wire from the radio is actually connected at the fuse box (or other power source). And is the fuse at the box still good?
If that's good, check the negative.
You can also check connection with the lighting harness, if there's a separate wire for that. If that wire is there, it usually will connect at the dimmer control on the dash.
Next, make sure the antenna is plugged in. Some radios are too smart for their own good and won't power up if there isn't an antenna (or speakers) connected, for fear of damaging components.
Make sure you try it with the ignition on, and the engine on.
If it's still a no-go, take the radio out, hook it to an antenna and connect it direct to a battery. If it still won't power up, you can either take it to get fixed at a local electronics repair shop, or turn it into a door-stop.
after i parked it came back bout 45 min later it said" D3 trk -5-," like the screen is going bad, any idea why? and is that fixable? it did get a lil cold but not the coldest this car has seen
Main fuse in the side bolster, to the left of the steering wheel?
You need the tools to pull the radio.If the radio fuse is blowing it's never good.
On the Delta there are two connections for power, Pin 3 and 8 of plug III
On the newer cars with concert stereo pin 3 is the K -line.
"just today i drove my car bout 5 miles was listing to a cd and on the screen it was saying "CD3 trk 5"
after i parked it came back bout 45 min later it said" D3 trk -5-," like the screen is going bad, any idea why? and is that fixable? it did get a lil cold but not the coldest this car has seen"
The displays tend to die after a while. Used replacements are available from posters here or on E-bay. Make sure you get the security code.
About 10 minutes work to replace with the radio tools.
rooster 2
03-09-2007 05:48 AM
My2ndS4
06-13-2004 08:19 PM
S4LUVR
Audi Original "S" Cars
05-12-2003 06:21 AM
