1999 2.8 timing belt change instructions
I'm new to the A4 but have done a few timing belt changes on various cars...just wondering if anyone can direct me to a good diy step by step write up? I will have the bently manual for the car, but i find that someone that's done it a few times and writes it up seems to be great first hand info...
thanks for any responses....yes, i've been searching..haven't found a good one here yet....
joe
joe
Did you look in the tech section? STFA?
Some tips:
Use the tools. Set the timing correct. Don't try to hack it up by marking stuff.
Replace all the upper engine seals; cam seals (4), cam adjuster seals (2), cam plugs (2), valve cover gaskets.
Use service position. No need to tear the whole rad support off.
Some tips:
Working on timing belt today
So I've got the front in the service position. Got the serpentine belt off , the top timing belt covers the tensioner.. Having problems with a bolt on the idler wheel bracket. It's so tight I stripped the freakin torx head...what do you do with that? It's the last damn bolt on the bracket..
I have it set at tdc, and have the cam alignment bar..
The water pumps tarted leaking like mo fo, so I figured I'd do the belt now. Car has 236k miles.
