2.7t or 1.8t swap
Old 05-10-2010, 02:59 PM
elye1231's Avatar
Default 2.7t or 1.8t swap
i know its a little harder but i heard its possible to swap the 2.8 engine for either the 1.8t or the 2.7t... is it possble? and will the tranny bolt straight on to the 2.7t?.....when i bought my 2.8 quattro the guy that had it before did a s4 conversion on all the body and on the interior. so itll be cool to finish the job. im new to this so please any info will help.....
Old 05-10-2010, 03:05 PM
Tech Guru
4Driver4's Avatar
Not again. Please, please STFA.
Old 05-20-2010, 06:51 PM
II IDUA's Avatar
i want to swap a 1.8 with the v8 4.2 fsi is that possible?
Old 05-20-2010, 06:56 PM
AudiMick's Avatar
Yes, there's a write up in the tech section.
Old 05-21-2010, 09:11 AM
II IDUA's Avatar
would the mounts be the same or would i have to customize
Old 05-21-2010, 09:58 AM
AudiMick's Avatar
Check the tech section.
I think it's the same mounts as the Pratt & Witney. But probably bungie cords would work.
Old 05-21-2010, 11:45 AM
adamgt's Avatar
Will an S4 bolt up to my 1.8T?
Old 05-21-2010, 11:56 AM
AudiMick's Avatar
I wouldn't use bolts I would suggest superglue gel as it's thicker and doesn't drip as much.
Not sure if that is in the tech section but it probably should be. Trust me!
Old 05-21-2010, 01:57 PM
turbo510's Avatar
Installing a G.E. T-58 turbine helicopter engine is the same amount of work, that's what I'm doing.
Old 05-21-2010, 05:23 PM
AudiMick's Avatar
I'm familiar with that option, but the special engine mounts are hard to find.
I believe they are made out of "unobtainium".
Quick Reply: 2.7t or 1.8t swap
