2.8 30V Still running rich after replacing common problem spots
Hey, my A4 has been running rich for a while now, but not enough to trigger a CEL or anything. It will actually drive just fine as well, but you can smell the fuel and the long term trim on both banks is about -18. It was actually way worse before I replaced the MAF sensor, always tripping a CEL and sputtering a lot, but now it's stinky but drivable.
I've replaced the spark plugs (old ones didn't look like they were from a rich running engine, still have them if someone wants pictures), Evap Purge Solenoid, MAF, vacuum lines, PCV tubing and valve itself, "tried" to clean the throttle body, and a new air filter. Also reading my o2 sensors, I can't tell if they're being slow, or if my OBD2 reader is just slow. I also know one of the cats had been recently replaced as well.
Okay so I'm gonna go ahead and do a fuel pressure test, pretty sure the leak down test will finally point out the culprit (my bets are on the fuel pump). Looking around I noticed that tapping into the fuel line had a VAG tool (1318) and I wanted to make sure if this is something that isn't unique to this, and that any fuel pressure tester can do the job. Just don't wanna rent one out to find it doesn't fit.
I'm also looking into checking the plug wires and coil pack since the pump was replaced not too long ago. The only other symptom I know of it that after being warm, it'll have a bit of an issue starting, like it's about to stall but then fixes itself back up. I heard a bad coolant sensor can cause this, replaced it, and now it does it less frequently.
You are certainly covering the bases. If you have checked the fuel pressure and verified it is in range then I would revisit the injectors. I do not know their characteristics well enough to be certain but I wonder how they perform as they age. Could they not leak but also either not spray but more dribble and maybe oversupply? This might also explain poor warm starts. Although the coolant temp sensor is more often the culprit. I have heard of poor performance from cheap non OEM replacements.
Not telling you to spend big bucks replacing injectors but I would research how they impact performance over time as they age.
Quick question about these engines, Bank 2 usually is the one that has a higher Long Term trim (19-21) and Bank 1 is usually always lower or equal to Bank 2. If one injector was dirty, bad, etc. on one bank, would that still cause the other side to have a rich condition? I always thought that a injector problem on one bank will only have the Trims affect that one bank, and the other would be normal.
Also, are the injectors okay to testing using 12 volts or should I use a 9 volt battery when testing the spray pattern?
97A4_UT
12-30-2006 10:48 AM
T-28-Quattro de VT
12-30-2002 04:28 PM
